Will loader from 300 Utility fit a 240 utility?
Posted by Tom Lassiter on July 12, 2001 at 20:08:54 from (63.102.170.99):
What loader brand/models will fit a 240 Utility?
I have the wide axle type,I suppose that is what it is called, as opposed to the tricycle type. Also are there other tractors models, that if I find a loader that fits one, automatically means it will fit my 240 utility? I read an article that said the hydraulic pumps on the 240 utility would not give good performance with the addition of a front loader. If this is the case, what should I do? Add a second pump? If so which would be better, a pump running off the engine belts or a 12 volt pump package like found on Tommy Lifts on truck tail gates? or perhaps another setup? It's all new to me and I am up for any help or suggestions. All of which will be most appreciated.
Post A Followup
: Re: Will loader from 300 Utility fit a 240 utility?
