Re: Steering box is shot on my Super A
Posted by Haas on July 13, 2001 at 05:11:11 from (129.37.117.242):
In Reply to: Steering box is shot on my Super A posted by Brian Coates on July 12, 2001 at 20:04:34:
If the fix suggested by Vern does not work, likely the bearings in the steering box are worn. You can check the thrust bearing on the worm gear by removing the big plug in the front of the steering gear and then screwing the worm out far enough to check the bearing for play. The bearing is easy to replace and cheap. You can get one at a Case IH dealer, or probably NAPA or just a bearing supply house if you have the old bearing with you. You can't take the worm all the way out unless you remove the steering wheel. Rebuilding the rest of the steering box is a bigger job. There are some other bearings in there that can also be replaced. If you put in new bearings, it will likely tighten up the steering quite a bit. To know if you can use the parts from a C, you will have to have a parts book for both the A and the C. Then you can check the part numbers and if they are the same, they will fit. The steering play on the A is a very common problem. If you find one that does not have much play, it means some one has rebuilt the steering box, or the tractor has been used little.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
