Re: 1959 International model140
Posted by planzman on July 13, 2001 at 13:02:45 from (198.26.132.99):
In Reply to: 1959 International model140 posted by Bob on July 11, 2001 at 16:06:24:
I got a 59 #140. Have disk, plow, blade, corn cultivator, planter, IH#10 (very wide) seed drill, model 46 IH baler (untried with the 140 in the field ), front and rear cultivators, and I would not take $5k for it. It is really a great little tractor. I want to get an "M" to handle the baler and some other heavier plowing.
Wengers in PA has everything you want including the front end loader. Frieght will be more than the implement so be warned.
good luck on your new tractor
Post A Followup
: Re: Re: 1959 International model140
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
