Re: 2 bottom IH Plow
Posted by Steve J on July 16, 2001 at 12:02:41 from (216.93.26.196):
In Reply to: 2 bottom IH Plow posted by Mike Wheels on July 15, 2001 at 18:25:24:
I have a wheel that might be what you are looking for. Where did you get the 26" measurment, though? The wheel that does not run in the furrow is a larger diamater than the one that does, so if you measured that wheel, the one you need is probably what I have, a 24" wheel. It has a 1 1/2" bore in the hub (which is cracked) for the axle shaft. I am located in the Lansing, Michigan area, and will give the wheel to you if you want to pay shipping. It is off from a 2 bottom IH plow, I do not know which model.
Post A Followup
: Re: Re: 2 bottom IH Plow
