Re: Help With H Steering!!
Posted by TomH on July 16, 2001 at 17:00:00 from (206.99.145.55):
In Reply to: Help With H Steering!! posted by 1PWRFULH on July 16, 2001 at 15:12:08:
You can take a lot of the slop out of the steering by tightening two nuts in the right order. There is a castle nut on the shaft that stops the worm when you turn the steering wheel to the left, the big plug stops it when the wheel is turned to the right. To adjust, turn the wheel to the right until it is against the plug, then tighten the castle nut to take out the slop. This is from memory but I think the directions are right, look at how the shaft moves when the plug is out and you'll see how it works.
Post A Followup
: Re: Re: Help With H Steering!!
