Re: Re: Re: Epoxy for brake lining?
Posted by Michael Soldan on July 16, 2001 at 20:13:37 from (216.46.140.186):
In Reply to: Re: Re: Epoxy for brake lining? posted by cheg on July 16, 2001 at 19:47:27:
Cheg, the circumstances warrant you returning the item for a replacement. If you only have 4 hours running time since you did the brakes it would seem to me to be defective material that you ended up with. A bonded brake lining should be good for years and years . I'm sorry I can't name an item for you but my guess is that there will be something on the market. My first move would be to ask for a warranty replacement. Good luck with it. Incidentally, the original M linings were riveted on. Both my H's have riveted linings, I'm guessing original or old replacement. Mike
Post A Followup
: Re: Re: Re: Re: Epoxy for brake lining?
