On some of the older tractors the ware on the linkage is sometimes wore bad and going by the book will not always give you the same results . So when you run into this you have to sorta FEEL your way through . First set the clutch free travel so that you have somewhere around 3/4 to 1 inch free travel , then remove the spring between the clutch arm to the T/A arm next remove the cover above the T/A clutch and adjust the linkage to the point where the T/A clutch throw out bearing is not touching the clutch fingers with about and 1/8th to 3/16ths of and inch clearance and see how that works . It is hard to explain as what i know comes from years of working on tractors i could show ya a lot easier then i can explain it . But since ya ain't my next door neighbor this will have to do . The book will get ya somewhat close but ya have to take into account that the book explains it for a new tractor or a tractor with little ware on the parts . Ware on the headed pins the slots in the clevis ware in the housings bushing all add up and make the book adjustment not work wright . So you use the book to get close and ya fine tune it by feel the rest of the way.
Today's Featured Article - The Tractor Parade: Story of a Case SC - by Bernie DeLon. On a early fall morning back in 1994, I opened the newspaper and happened to spy an article about a local antique tractor club having their annual show that weekend.
... [Read Article]
Latest Ad:
[More Ads]
