Farmall Tractors Discussion Board
ballast resistor
Posted by wayne gulliver on February 25, 1999 at 12:29:12:
Dear Forum Friends
I have changed my Super C over to 12 volts and have also installed a 12 volt coil as the 6 volt one burnt out. Do I still need the ballast resistor in series with the coil to reduce voltage at the points? Appreciate some input. Thanks
Wayne
Post a Followup
: Re: ballast resistor
