charging dilemma unfolding on M????
Posted by joe on July 17, 2001 at 15:57:14 from (24.23.11.91):
per red i did connect a wire from amp box to f post on generator according to instrcutions. didnt do anything. I did use a volt meter and tested 12 volt battery. 12.4 or so when off. when tractor is running 13 and some change does not stay exact fluctuates slightly with throttle movement. at the same time amp meter is -10 or so. whats lying to me ??? i let tractor run 20 min or so and battery still shows 13 and change volts on meter. shouldnt the battery be draining??? to those who dont know amp meters reads -10 at all times when i turn key on. nothing has been able to correct this.
Post A Followup
: Re: charging dilemma unfolding on M????
