Re: FARMALL H CRACK IN CYCLINDER
Posted by The Red on July 18, 2001 at 09:12:09 from (206.246.187.2):
In Reply to: FARMALL H CRACK IN CYCLINDER posted by Dave Kingsley on July 17, 2001 at 16:32:31:
Unless that crack just happens to be where you can access it from the water jacket inpsection plate side and repair it, it will leak coolant. The probability is low on fixing that crack. The dry sleeve will not prevent it from leaking.
Post A Followup
: Re: Re: FARMALL H CRACK IN CYCLINDER
