Re: 300U lift ???
Posted by mhufnagel on July 18, 2001 at 10:12:39 from (12.31.22.101):
In Reply to: 300U lift ??? posted by Dale on July 14, 2001 at 22:32:09:
I'm coming into this one late. The fluid foaming implies you have an air leak in the suction line to your pump. This could be anywhere from the inside of the reservoir to the flange of the pump itself. The situation would be aggravated if the suction screen was clogged as well. My 300U had a piece of rubber hose in the suction line that was collapsed internally, which starved the pump and caused a similar problem. If your machine has its original lines intact, you shouldn't have this problem. Note that the suction screen is the only filter in this hydraulic system, and it's not very good. I actually added a high pressure filter to the pressure line, and the system works much better.
Post A Followup
: Re: Re: 300U lift ???
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
