C seat mount/pivot
Posted by SDE on March 15, 2009 at 10:10:17 from (75.121.152.32):
third party image
I removed the seat support arm. Someone had removed the original bushing at the pivot point and put two nuts in its place and then put the 1/2 bolt back in. The nuts are now wore out. The bore is 1.00 in the center and 1.125 at the sides.
Was the original bushing a rubber coated steel bushing? Are these bushings made of steel or some other material?
Thank you Steve
