Re: Questions about paint...
Posted by Dave t on July 19, 2001 at 08:55:09 from (63.20.49.182):
In Reply to: Questions about paint... posted by ff316 on July 19, 2001 at 08:06:22:
What are you going to use it for? How much are you willing to spend? Your Case/IH paint does oxidize pretty quickly, but if it's a work tractor, who cares? If you are painting to show and don't plan to use it, I would recommend the PPG OMNI. It's not expensive as Dupont. Whatever system you use, whether it's single stage, two stage urathane, or enamel from Case, you need to use the correct primer and other stuff needed for that system. You can't use rattle can primer and expect urathane paint to stick.....Your Napa store carries Martin Seniour paint, and your big store can mix up a single stage urathane for you too.
Post A Followup
: Re: Re: Questions about paint...
