Re: Steering u-joint on 41 M
Posted by The Undertaker on July 20, 2001 at 12:47:13 from (64.40.66.124):
In Reply to: Steering u-joint on 41 M posted by Gary on July 20, 2001 at 12:30:41:
Gary:
My "H" universal is as you describe your "M" and I'm curious about the type universal you have. One I have is equipped with the spider having stamped steel bolted together with four bolts and nuts that contains the steel rod dowel. The other is an assembly comprised of a cast spider with the bearing cups and needles. Which would yours be?
"TU"
Post A Followup
: Re: Re: Steering u-joint on 41 M
