Re: Bob M Haas, M with gas/kerosene/diesel
Posted by Bob M on July 20, 2001 at 17:52:01 from (66.66.72.246):
In Reply to: Bob M Haas, M with gas/kerosene/diesel posted by 230,H,M on July 20, 2001 at 17:17:47:
You are correct - that's what the decompression (starting) lever does. When you pull the lever back it opens an 3rd valve in each cylinder. This opens a passage to an auxiliary (starting) chamber in each cylinder. This reduces the compression ratio from about 14:1 to about 5(?):1, making the motor much easier to crank. Each starting chamber also contains a spark plug. The starting lever also does several other things: It switches a pair of butterfly valves in the manifold so incoming air passes thru the carburetor, releases the carb float so the carb can fill with gas, and closes the circuit to the ignition coil primary. Thus pulling the starting converts a high compression, fuel injected diesel engine into a low compression, spark ignition gasoline engine. Once the motor is started and warmed a minute or two on the gasoline cycle, pushing the lever back in reverses all of the above, and enables the diesel cycle. The motor then runs like any other diesel. It's a rather complex solution to the problem of starting a diesel engine with a low-powered electric starter. Some other mfr's - Deere and Caterpillar - solved the problem by utilizing a separate 2 or 4 cylinder gas starting (pony) motor to crank up their early diesels.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
