Re: FARMALL H CRACK IN CYCLINDER
Posted by Farmer on July 20, 2001 at 19:05:13 from (204.186.219.126):
In Reply to: FARMALL H CRACK IN CYCLINDER posted by Dave Kingsley on July 17, 2001 at 16:32:31:
Well I am not sure that I have ever heard that happen before. I would think that you would be able to just put in the new sleeve in. Your right that it would keep out the coolant, however I am not sure that the cilander would give you good compression. I have an old Farmall Super "C" and for awile it would only run on 3 cilanders becuse of lost compression. Im sure that the crack is too small and at too odd of an angle to have it welded. I would have to say that you should tell an expert at an International dealer. I am not sure where you are from but I have a number of one here in PA you could try. "Ludwig's Farm Supply." 1-(570)682-9297
Good luck and sorry I could not be of much help!!
Farmer
Post A Followup
: Re: Re: FARMALL H CRACK IN CYCLINDER
