Re: super H vs. M
Posted by MarkNOhio on July 21, 2001 at 00:16:11 from (207.90.109.141):
In Reply to: super H vs. M posted by farmer Nick on July 20, 2001 at 19:59:03:
I agree with Sven, buy both of them! Seriously though, I've bailed thousands of bales of hay/straw with a non Super H....mine is a '49. You'll miss not having a live PTO, but if you're quick on the clutch/gearshift it's not a big problem. Normally if you start to bog down, the flywheel on the bailer will keep things turning long enough for you to disengage the clutch, shift to neutral, and re-engage the clutch. Just make sure if you're on any kind of a hill to also hit the brakes!
Post A Followup
: Re: Re: super H vs. M
