Re: Bob M Haas, M with gas/kerosene/diesel
Posted by Haas on July 21, 2001 at 04:37:33 from (129.37.117.131):
In Reply to: Bob M Haas, M with gas/kerosene/diesel posted by 230,H,M on July 20, 2001 at 17:17:47:
On my MD and every other one I have seen, when the starting (switchover) lever is forward, it is in gas mode. Pulled back to the rear is diesel mode. The others have given you an adequate explanation of all that happens when you move that lever. All the linkages that are worked by that lever have to be in proper adjustment or the starting system may not work.
Post A Followup
: Re: Re: Bob M Haas, M with gas/kerosene/diesel
