Re: honing cylinders
Posted by Doc on July 23, 2001 at 20:59:29 from (216.177.138.244):
In Reply to: honing cylinders posted by Chuck M on July 21, 2001 at 19:18:07:
I have used a number of oils and lubes and the best I have found is WD-40. It keeps the stones free of grit, cleaning as you hone and leaves the bore completely visible so you can watch the cross hatch. Don't forget to clean the honing grit. Best is hot soapy water and a good wash cloth. I have seen many sets of bearings ruined by honing grit. Wash thoroughly, dry and oil. This will give you an engine you could eat out of. Doc
Post A Followup
: Re: Re: honing cylinders
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
