Re: 300 leaking water in a bad, bad place
Posted by 2ulew on July 23, 2001 at 22:18:46 from (206.58.190.149):
In Reply to: 300 leaking water in a bad, bad place posted by doug vose on July 23, 2001 at 21:57:48:
Doug, Run the wet piston to TDC and if the water runs into the pan then it is a problem in the cylinder wall. If it still runs in above the piston it is gasket or head problem most likely.
Good luck Lew
Post A Followup
: Re: Re: 300 leaking water in a bad, bad place
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror ... [Read Article]
