Re: Re: 140 what would you pay?
Posted by James on July 24, 2001 at 18:59:39 from (165.247.129.149):
In Reply to: Re: 140 what would you pay? posted by Don(PA) on July 24, 2001 at 18:34:28:
Thanks for the advice, I was hoping not to spend over $3500 but I wanted to get a good machine. Have you had good luck with your tractor, did you get it at a auction or from someone. Thanks in advance
Post A Followup
: Re: Re: Re: 140 what would you pay?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
