Re: Re: Re: Re: Re: Farmall 300, Farmall M
Posted by J.C. on July 25, 2001 at 16:12:06 from (64.17.78.82):
In Reply to: Re: Re: Re: Re: Farmall 300, Farmall M posted by Mark Steele on July 25, 2001 at 13:12:50:
Two things. 1. Go to the auto parts store and buy one of those syphon pump things and use it to syphon the transmission fluid out of the cylinders. Transmission fluid will never work. Then get yourself something good like Kroil, PB Blaster, or Gibbasize to fill up the cylinders and let it soak for a while. If it does not come loose soon, you can pull the head and get more serious with it. Maybe you can get it running without pulling the head.
2. On the TA, it seems like I have heard of TAs being removed and going to direct drive. I would not reccomend this. If you go through the process of splitting the 300, go ahead and replace the TA. A rebuilt unit costs about $400. You should also replace the engine clutch and TA clutch if your that far into it.
Post A Followup
: Re: Re: Re: Re: Re: Re: Farmall 300, Farmall M
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
