Re: 1949 Farmall M PTO
Posted by The Red on July 26, 2001 at 10:11:28 from (206.246.187.2):
In Reply to: 1949 Farmall M PTO posted by Gary Blackford on July 26, 2001 at 10:01:19:
I am looking at the H parts book which is similar to the M pto. There is a poppet and a spring that is involved with the shifter arm so it will stay in either the up or down position. Sounds like that spring and poppet is missing on your PTO housing located in the vicinity of the shift arm.
Sounds like a new gasket will take care of your leaking at the base.
Post A Followup
: Re: Re: 1949 Farmall M PTO
