Farmall Regular Fuel Tank Caps
Posted by JohnG(TX) on July 26, 2001 at 19:46:59 from (216.198.60.108):
I have seen two different types of fuel caps on the Farmall Regular. Both are screw-on type, but one has many threads, and the other has only about a quarter turn to lock. Is there a year difference to these, or is it a factory/replacement issue? I would like to know which one is correct for my 1929. The small gasoline tank has the type with many threads and I have both styles on two larger tanks. Thanks.
Post A Followup
: Re: Farmall Regular Fuel Tank Caps
