Re: Re: 3 point
Posted by PaulH on July 26, 2001 at 21:39:04 from (199.240.239.201):
In Reply to: Re: 3 point posted by haas on July 26, 2001 at 14:59:50:
If you have a factory remote valve, you can get dual action (up/down) by connecting the top of the cylinders to the return line from the remote. This valve connects to the fill tube on the hydraulic belly pump via a Tee fitting. The same thing could be done with an aftermarket valve. The point is, if you do this, as oil goes out to one end of the cylinders, it returns from the other end, so the volume required is less. I am running a 1950 M with a Saginaw 3-point on a belly pump with factory remote. It has dual 3x8 cylinders, and will lift anything the tractor is heavy enough to hold. With down force, you can easily raise the tractor's rear wheels off the ground. I use a heavy 8 ft rear blade and 6 ft brush hog with this, and it works great. The only problem is that the fill tube tends to blow out some oil if I keep the vent open with the remote valve activated. I can't close the vent because the belly pump seal is not that great, and internal pressure will blow oil out the shaft seal. Guess I need to replace the seal. As Haas replied, I think you'll be fine with single acting from the standard pump connections if you just need one-way action (lift only). Just be sure to put vent plugs on the tops of the cylinders. Have fun with this, and holler if you need any help with the plumbing; lots of people on this board have put 3-point hitches on M's.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
