Re: factory remote valve
Posted by Doc on July 27, 2001 at 23:09:07 from (216.177.138.130):
In Reply to: factory remote valve posted by Jess on July 27, 2001 at 18:48:23:
How many levers do you have for hydraulic control? Do you have hoses to the back of the tractor? There should be one lever for the belly pump coming from the clutch housing. If you have the remote valve you should have another lever on top of the belly pump lever. I you have the factory remote valve,you will see it mounted on or near the fill for the belly pump. Of course on an old tractor you could have any one of a number of add on pieces.
Post A Followup
: Re: Re: factory remote valve
