Re: Farmall B getting hot
Posted by The Red on July 28, 2001 at 11:01:36 from (12.84.239.37):
In Reply to: Farmall B getting hot posted by Randy McCoy on July 28, 2001 at 10:35:55:
Take a flashlight and make sure you can see around the cooling pipes in the radiator. It might be jammed with dirt and not letting much airflow through the radiator.
Post A Followup
: Re: Re: Farmall B getting hot
