Re: Farmall M hints on where to start
Posted by Mike on July 28, 2001 at 15:24:36 from (152.163.197.208):
In Reply to: Farmall M hints on where to start posted by Barry on July 28, 2001 at 15:04:17:
Welcome to the world of red machines. Yes you will see oil in the valve train but not right away. you will certainly be able to tell if a valve is stuck. A couple more ideas may be to pull plugs and put some not alot of oil in each cylinder to prevent scoring of the cylinders. Can you roll it over by hand with valve cover off and watch valves? I also might install a known working oil pressure gauge to prevent running very long with no oil pressure. I'm no expert but a few ideas for you and good luck.
Post A Followup
: Re: Re: Farmall M hints on where to start
