Re: Farmall M hints on where to start
Posted by JDM on July 28, 2001 at 15:51:16 from (206.74.34.164):
In Reply to: Farmall M hints on where to start posted by Barry on July 28, 2001 at 15:04:17:
Suggest that you at least change the oil,filter, and coolant if you havent already done so.With the valve cover off make sure all of the valves are opening and closing properly.IF you are worried about the oil pressure,make sure the switch is off to the mag and turn it over for a few seconds at a time to make sure oil gets up to the rocker arms.
Post A Followup
: Re: Re: Farmall M hints on where to start
