Re: Farmall B getting hot
Posted by gene b on July 28, 2001 at 16:21:48 from (63.25.167.60):
In Reply to: Farmall B getting hot posted by Randy McCoy on July 28, 2001 at 10:35:55:
chances are the block is plugged at the bottom of the sleeves there are 5 holes for the water to go down thru and out past the sleeve and to the bottom outlet on the block i would remove the radiator and take the lower housing off bet you will get lots of jund out with air hose and a long screwdriver have torn down sever in the last few yrs and when the sleeves are pulled for over hhaul you would be surprized at the buildup in this area had this happen on a BN few yrs ago and did the above procedure ended the problem a water pump installed at this time will also help if you will put a piece of copper tubing on your air gun it will help get to the rear of the block use air then water probably improve the cooling to a more workable deal would be easier if you could see a bare block then you would understand what I am talking about you will find more junk as you work towards the rear of the block dont push any thing too long as there is a frost plug at the rear and you dont want to knock it loose or then you will have to split the engine from the bell housing
Post A Followup
: Re: Re: Farmall B getting hot
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
