Re: Re: siezed W6
Posted by Michael Soldan on July 29, 2001 at 07:29:08 from (216.46.140.186):
In Reply to: Re: siezed W6 posted by DC on July 29, 2001 at 05:00:19:
DC, I would take the same approach as you. I would suggest that the rear wheel should be rocked back and forth to allow the pistons to move in both directions as they work loose. If you try turning the wheel around the piston must shove through all rust all the way up or down the cylinder,working it each way will prevent jamming the pistons. Rocking also allows the cylinder walls to clean themselves both ways, little by little. Our approach is similar and could save a lot of work.
Post A Followup
: Re: Re: Re: siezed W6
