Re: Re: siezed W6
Posted by The Red on July 29, 2001 at 08:44:47 from (12.84.241.156):
In Reply to: Re: siezed W6 posted by DC on July 29, 2001 at 05:00:19:
While unsticking Old Rusty H, I first used Marvel Mystery Oil for the first month with no results. Once I began using the PB Blaster, it started penetrating between the sleeves and the cylinder walls in less than two weeks. Once I had the sleeves/pistons out, I pounded the pistons out of the sleeves. I could clearly see that the PB had penetrated past the first and second compression rings but not the third on 3 of the 4 pistons. It appears to be the better penetrant in my opinion.
Post A Followup
: Re: Re: Re: siezed W6
