Re: Re: M governor rebuild
Posted by Dan on July 29, 2001 at 15:08:20 from (12.18.158.25):
In Reply to: Re: M governor rebuild posted by The Red on July 29, 2001 at 08:36:59:
I know at least pins and weights are still available from IH, didn't say cheap just available. Helps to have service book as it points out wear points. Check bearings in the front, check wear between pins and weights or oblong holes, also that thrust bearing is ok and moves on shaft. might want to replace the spring while there. definitely helps to have service book to get order this all comes apart.
Post A Followup
: Re: Re: Re: M governor rebuild
