Re: Super M Knock-Knock-Knock
Posted by Bob M on July 29, 2001 at 17:57:30 from (66.66.72.246):
In Reply to: Super M Knock-Knock-Knock posted by Ed Fisher on July 29, 2001 at 10:05:47:
Ed - Possibly the cam gear has come loose on it's hub - i.e. the nut on the end of the camshaft has worked loose. Best way to check without tearing down the whole front end of the tractor: Turn the motor so it's at TDC with #1 cylinder firing. Then unbolt and remove the hydraulic pump/distributor. You will plainly see top of the cam gear in the opening. Now rock the crank back and forth 1/8 turn or so (use the fan as a handle) and watch the cam gear. If the cam gear shows any axial play you've found your problem.
The camshaft nut unscrewed and fell off on my SM, resulting in an ominous knocking sound like you describe. The gear was so loose I could move it fore and aft about 1/2" just by pushing it with my fingers. Installing a new gear and camshaft nut cured the knock. Punch below for some images of the teardown and repair. ...Bob M
Post A Followup
: Re: Re: Super M Knock-Knock-Knock
