Farmall Tractors Discussion Board
Re: superMTA Diesel hydraulics
Posted by Fudd on February 26, 1999 at 18:34:30:
In Reply to: superMTA Diesel hydraulics posted by Robert DeWilde on February 26, 1999 at 08:32:46:
I had the same problem with my 400 and the pump was wornout. You need a manual to correctly check the pump pressure before doing anything. It won't do any good to turn it up if the pump isn't producing in the first place. What size cylinder do you have on your splitter? If it isn't big enough, the tractor might be doing it's job but not acting like it. Good luck, Ron
Post a Followup
: Re: Re: superMTA Diesel hydraulics
