Re: Farmall C Starter Question
Posted by Haas on July 30, 2001 at 03:52:52 from (129.37.117.231):
In Reply to: Farmall C Starter Question posted by phil on July 29, 2001 at 21:11:08:
Is the starter spinning when you pull the rod and not engaging, or is it just not doing anything?? Or does it grind?? When the starter was rebuilt, did they replace the contact button that is under the switch??
Post A Followup
: Re: Re: Farmall C Starter Question
