Re: Farmall H Oil and brakes
Posted by Michael Soldan on July 31, 2001 at 17:16:12 from (216.46.140.186):
In Reply to: Farmall H Oil and brakes posted by Donald Andersen on July 31, 2001 at 10:18:23:
Don, just to add to the Red's comments, the adjustment in H brakes is in the yoke only. Make sure you have the screws at the bottom of the brake pan turned all the way in , then let off about a half turn. That holds the brake bands in place. As the Red said the bolt in the yoke might not want to come out. I had to heat mine red hot to move them and I even broke one when it was red hot. After you have freed the adjusters make sure that both sides have the same response, feel if you like, so that both brakes are equalized. When you road test lock the pedals together and you should be able to tell if both brakes are responding together..and if everything is right you should be able to slide the wheels. There is the possibility that the brake bands are worn, but the adjusters should tell the story at a glance. Good luck from Mike in Exeter Ontario
Post A Followup
: Re: Re: Farmall H Oil and brakes
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
