Re: Time to stop smoking!
Posted by Zonie on July 31, 2001 at 18:56:10 from (205.188.192.44):
In Reply to: Time to stop smoking! posted by lfrye on July 30, 2001 at 21:33:01:
My H was smoking pretty bad and the oil pressure was pretty low , then It just started knocking . So I decided that it was time for an overhaul. I planned a inframe overhaul but it has turned out otherwise. The crank was too badly scored. I need to split my tractor also.My books say I can not remove my crank with out doing this. I've never split one befor either.
I rounded up some large wood timbers about the size of railroad ties and will crib up the back half under the flywheel housing. I did this awhile back when I removed the front bolster and it works very well.
I did fabricate my own sleeve puller that worked very well but it did take quite a bit of time to build alot of trial fitting and such. Rent one if you can find one to rent!
Post A Followup
: Re: Re: Time to stop smoking!
