Re: Need some cyber help for a 1949 Farmall Cub magneto
Posted by Alan Rainford on August 01, 2001 at 06:00:52 from (156.24.1.36):
In Reply to: Need some cyber help for a 1949 Farmall Cub magneto posted by James Duckett on July 28, 2001 at 10:26:54:
A 49 Cub should use a Wico Distributor I think its a model XB and looks very much like the Mag used on older equipment. You should see a wire for connecting 6v of power to it as it needs power for the coil inside (no magnets just coil). If you are using 12v you MUST use a balast resistor to drop the voltage or the points and coil will burn up in a very short time.
Let me know how it works...
Alan
47 Cub owner
Post A Followup
: Re: Re: Need some cyber help for a 1949 Farmall Cub magneto
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
