Farmall Tractors Discussion Board
Re: where do you check the oil levels on a 240?????
Posted by Jim Becker on February 26, 1999 at 20:31:31:
In Reply to: where do you check the oil levels on a 240????? posted by ZANE on February 25, 1999 at 19:16:47:
Thought someone that was sure would have answered this by now. Here is my best shot, partly from memory, partly a guess.
Engine: dip stick.
Transmission/differential: level plug at rear, right side, hole drilled in Fast Hitch mounting frame for access.
Hydra Touch: the filler plug on top of bell housing (1/2 inch below hole).
Steering gear: behind grille, the lower of the 2.
Post a Followup
: Re: Re: where do you check the oil levels on a 240?????
