Re: Re: Re: Re: Farmall M with hand clutch
Posted by Denny Frisk on August 02, 2001 at 06:57:25 from (12.4.181.2):
In Reply to: Re: Re: Re: Farmall M with hand clutch posted by Haas on August 02, 2001 at 05:32:37:
I agree Haas, The "Lift-ALL" and the PTO run off the same shaft in the transmission, except the PTO has the shifter in the rear end tub, so if the PTO can run LIVE, the Lift-All can run live too. The other guy has the M&W Live Hyd. on His M which was used to run is power steering. There's NO WAY the little Saginaw P/S pump used on the Char-Lynn P/S kits could run anything more than the P/S, and they even had problems with THAT! The later Numbered series with the Behlen P/S used the live hyd to run their P/s
Post A Followup
: Re: Re: Re: Re: Re: Farmall M with hand clutch
