SMTA Loose Foot Pedal
Posted by GooseCreek on August 02, 2001 at 19:24:56 from (198.111.150.164):
The clutch on my SMTA is loose on the shaft. Took it off planning on drilling it out and intallling a bushing. However discovered that the shaft is worn badly. Now thinking about removing the shaft the pedal is on and welding it and then grinding it back to it's original dia. My question is can I just pull out the shaft? Is there any internal transmission parts connected to it? Also would appreciate any other suggestions to fixing my problem.
Post A Followup
: Re: SMTA Loose Foot Pedal
