Re: Re: rust in wd-9 tank
Posted by Mark on August 03, 2001 at 05:40:06 from (207.136.5.72):
In Reply to: Re: rust in wd-9 tank posted by Carp on August 02, 2001 at 20:10:08:
Hey. I have found the best way of doing it , is to rig up an air hose under about 10-15 lbs. of pressure. Then adding about a pound of a good blasting medium, like walnut shells or plastic beads, and just letting it swirl around for a few hours. Then I use a small attachment I made for my shop vac, and just vaccumm all the crap out of it. I have cleaned out a lot of really nasty fuel/gas tanks this way. Hope this helps. Mark
Post A Followup
: Re: Re: Re: rust in wd-9 tank
