Re: 7ft sickle bar mower on an A
Posted by Andy Martin on August 03, 2001 at 13:27:23 from (63.25.216.48):
In Reply to: 7ft sickle bar mower on an A posted by Michael on August 03, 2001 at 13:06:36:
When using it, watch out for dogs, trees, and junk iron in the field. Dogs unfamiliar with sickle mowers will chase the tractor and lose a foot when the sickle bar comes past. Don't try to mow when it is wet or damp. Keep the sections sharp, and don't try to go too slow. Dryer conditions and taller grass let you mow with duller sections. Speed helps push the grass into the cutterbar. You should be able to cut fine in 3rd at full throttle if the field is smooth enough. If the mower is in good shape and the mounting is tight it should not shake much. A balanced head mower shakes less, but I assume you have a pittman mower. Only engage the PTO when the clutch is disengaged. If you have a pittman mower (with a wooden connecting arm) the cutter bar need to be almost down before engaging. With most wobble head mowers you can engage in any position. With the cutter bar vertical this is handy for mowing brush going into and out of the field. If you get grass hung up in the mower trying to start, back up to lay the grass back. Then when you start you are not trying to cut until the mower gets some speed. This may happen if the grass is wet underneath. Bolts for sections are available and are much better than rivets. After I went to bolts I rarely lose a section from trying to cut small branches and small trees/brush. The bolts are well worth the money.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
