Re: Whole tractor gasket set?
Posted by justin on August 03, 2001 at 19:38:01 from (209.23.129.28):
In Reply to: Whole tractor gasket set? posted by Tom in Mo. on August 03, 2001 at 18:54:57:
Ih did produce a chassis gasket set for all the older tractors, but they have not been produced for some time.. If you do find one the probability will be that the gaskets have shrunk and become brittle. All the gaskets are still available and are relatively inexpensive.. Engine gaskets can be bought at your local dealer or at NAPA.. As far as oil seals are concerned, you can get them cheaper than your local case IH dealer by going thru NAPA, but their are some seals that case IH can get that NAPA cannot.. Putting gaskets and seals in a tractor is relatively inexpensive.. it is when you put new bearings in the tractors which makes the repairs more expensive..
Post A Followup
: Re: Re: Whole tractor gasket set?
