Re: Postive battery cable connected to block???
Posted by The Red on August 04, 2001 at 09:18:55 from (12.84.243.211):
In Reply to: Postive battery cable connected to block??? posted by Sue on August 04, 2001 at 09:14:41:
Sue the original configuration was positive ground. Remove the cover on the voltage regulator and make sure the points are opening as you are shutting down the tractor. If they are stuck closed, you will run a battery down in a couple of hours. Does the ampmeter gauge work?
Post A Followup
: Re: Re: Postive battery cable connected to block???
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
