Re: Re: Re: NO POWER !!!!!!!!!!!!!
Posted by The Red on August 05, 2001 at 07:02:43 from (12.84.240.237):
In Reply to: Re: Re: NO POWER !!!!!!!!!!!!! posted by Seth Roemer on August 05, 2001 at 06:47:15:
Remove the rocker arm assembly and re-torque the head nuts to 75 foot pounds. Start in the center of the head and work out in a circular pattern. You will then need to reset the valve clearances. I set them at .018 cold. Let us know if the head nuts were way out of torque. I had this problem on the 51H rebuild of 2 years ago. I also had problems getting the #1 exhaust valve to seat. When I checked the clearances a couple of times over the first 30 hours, it had no clearance and wasn't fully closing.
Also I recommend you change the oil and filter at this point.
Post A Followup
: Re: Re: Re: Re: NO POWER !!!!!!!!!!!!!
Today's Featured Article - Memories of an IH Super A When I was ? up to 10, I worked on my Papaw's farm in Greeneville, TN every summer. As I grew older (7), it was the thrill of my day to ride or drive on the tractor. My Papaw had a 1954 IH Super A that he bought to replace a Cub. My Papaw raised "baccer" (tobacco) and corn with the Super A, but the fondest memory was of the sawmill. He owned a small sawmill for sawing "baccer" sticks. The Super A was the powerplant. When I was old enough (7 or 8), I would get up early and be dressed to ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
