Re: Farma;; A 's RH REAR AXLE BEARING BAD
Posted by the tractor vet on August 05, 2001 at 18:46:16 from (216.196.13.85):
In Reply to: Farma;; A 's RH REAR AXLE BEARING BAD posted by ThatOtherGuy on August 05, 2001 at 18:37:24:
It's not all that bad you should be in and out of it in say about 5to6 hours of fumbelen it take me about 4with cleanen parts and chasen parts and i don't htink it will require getting a second morgage on the farm two bearings a coupel of seals and a gskt some where around 100to125 bucks, but you my find more then you want so be prepaird for the shock . Oh yea i cheet i use and impact and a cherry picker.
Post A Followup
: Re: Re: Farma;; A 's RH REAR AXLE BEARING BAD
