Re: farmall h magneto problems--help!!!
Posted by Red Dave on August 06, 2001 at 05:59:47 from (208.165.46.34):
In Reply to: farmall h magneto problems--help!!! posted by derek csendom on August 05, 2001 at 20:05:37:
Don't take the mag off. If it ran before you worked on it, it's probably just something back together wrong. Make sure the plug wires are on in the right order. #1 should be marked on the distributor cap the firing order is 1, 3, 4, 2. #1 cylinder is closest to the radiator. Recheck your work and check your point gap, it should be 0.013 on a magneto. Good Luck
Post A Followup
: Re: Re: farmall h magneto problems--help!!!
