Re: Re: Grease in water passages, how to remove?
Posted by big fred on August 06, 2001 at 10:50:38 from (12.13.226.13):
In Reply to: Re: Grease in water passages, how to remove? posted by Michael Soldan on August 05, 2001 at 18:43:15:
Thanks for kick startin' my brain. I guess I wasn't thinkin' clearly. All I gotta worry about is dissolving the grease, then I can rinse any crud outa there with a good flushing before I put the radiator on. Of course water will flow thru there if it's coming out of the garden hose.
Post A Followup
: Re: Re: Re: Grease in water passages, how to remove?
